Unable to launch Automation Hub and Apps with proxy setup
Solutions for Automation Hub and Apps launch failures with proxy configuration on EKS/AKS.
Description​
If you use a proxy setup, you may run into issues when trying to launch Automation Hub and Apps.
Solution​
You can fix the issue by taking the following steps:
  1. Capture the existing coredns configmap from the running cluster:
    kubectl get configmap -n kube-system coredns -o yaml > coredns-config.yaml
  2. Edit the coredns-config.yaml file to append the FQDN rewrite to the config.
    1. Rename the configmap to coredns-custom.
    2. Apply the correct configuration depending on your platform:
      • For AKS, define a new CoreDNS zone for the FQDN, as shown in the following example:
        apiVersion: v1
        kind: ConfigMap
        metadata:
          namespace: kube-system
        data:
          <FQDN>.server: |
            <FQDN>:53 {
                errors
                log
                health
                rewrite stop {
                    name exact <FQDN> istio-ingressgateway.istio-system.svc.cluster.local
                kubernetes cluster.local in-addr.arpa ip6.arpa {
                  pods insecure
                  fallthrough in-addr.arpa ip6.arpa
                prometheus :9153
                forward . /etc/resolv.conf
                cache 30
                loop
                reload
                loadbalance
        apiVersion: v1
        kind: ConfigMap
        metadata:
        data:
          <FQDN>.server: |
            <FQDN>:53 {
                errors
                log
                health
                rewrite stop {
                  pods insecure
                prometheus :9153
                cache 30
                loop
                reload
                loadbalance
      • For EKS, it is enough to add only the rewrite block to the existing CoreDNS Corefile:
        rewrite stop {
        rewrite stop {
  3. Create the coredns-custom configmap:
    kubectl apply -f coredns-config.yaml
  4. Replace the volume reference from coredns to coredns-custom in the coredns deployment in kube-system namespace:
    volumes:
      - emptyDir: {}
      - configMap:
          defaultMode: 420
          items:
          - key: Corefile
            path: Corefile
    volumes:
      - emptyDir: {}
      - configMap:
          defaultMode: 420
          items:
          - key: Corefile
            path: Corefile
  5. Restart the coredns deployment and ensure the coredns pods are up and running without any issues:
    kubectl rollout restart deployment -n kube-system coredns
  6. You should now be able to launch Automation Hub and Apps.
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
