Proxy
Configure HTTP and HTTPS proxy settings for Automation Suite on EKS/AKS.
To deploy Automation Suite in a proxy configuration, you must configure your cluster and add all UiPath® required domains to an allowlist in your network proxy.
A proxy configuration is required only if you perform an online installation.
Configuring the cluster
For instructions on how to configure the cluster worker nodes in proxy mode, refer to the Microsoft or AWS documentation:
When configuring the cluster nodes in proxy mode, make sure to add the following domains to the no_proxy list:
  • EKS
    "$VPC_CIDR,$SERVICE_CIDR, localhost,127.0.0.1,169.254.169.254,<clusterfqdn>,.<clusterfqdn>,.internal,.eks.amazonaws.com,.cloudfront.net,s3.CLOUD_REGION.amazonaws.com,.s3.CLOUD_REGION.amazonaws.com,.dkr.ecr.CLOUD_REGION.amazonaws.com,ec2.CLOUD_REGION.amazonaws.com,api.ecr.CLOUD_REGION.amazonaws.com,.elb.amazonaws.com,.gr7.CLOUD_REGION.eks.amazonaws.com,.s3.amazonaws.com,kubernetes,kubernetes.default,kubernetes.default.svc,kubernetes.default.svc.cluster,kubernetes.default.svc.cluster.local,.svc,.svc.cluster,.svc.cluster.local,.svc.cluster.local.,argocd-repo-server,istiod.istio-system.svc,logging-operator-logging-fluentd.logging.svc.cluster.local,argocd-repo-server,.local,.cluster,ai-helper-svc,ai-pkgmanager-svc,ai-deployer-svc,ai-appmanager-svc,ai-trainer-svc"
  • AKS
    "<cluster-fqdn>,.<cluster-fqdn>,localhost,127.0.0.1,10.0.0.0/8,mcr.microsoft.com,kubernetes,kubernetes.default,kubernetes.default.svc,kubernetes.default.svc.cluster,kubernetes.default.svc.cluster.local,.svc,.svc.cluster,.svc.cluster.local,.svc.cluster.local.,argocd-repo-server,istiod.istio-system.svc,logging-operator-logging-fluentd.logging.svc.cluster.local,argocd-repo-server,.local,.cluster,ai-helper-svc,ai-pkgmanager-svc,ai-deployer-svc,ai-appmanager-svc,ai-trainer-svc"
Note:
Make sure to replace <cluster-fqdn> with the actual FQDN URL.
Providing proxy setting in input.json
Configure the input.json file with the following parameters:
Mandatory parametersDescription
enabledUse true or false to enable or disable proxy settings.
http_proxyUsed to route HTTP outbound requests from the cluster. This should be the proxy server FQDN and port.
https_proxyUsed to route HTTPS outbound requests from the cluster. This should be the proxy server FQDN and port.
no_proxyComma-separated list of hosts, IP addresses, or IP ranges in CIDR format that you do not want to route via the proxy server.
The list must be the one provided in the Configuring the cluster section for EKS or AKS, respectively.
Example input.json for proxy configuration:
"proxy": {
  "enabled": true,
  "http_proxy": "http://<PROXY-SERVER-IP:<PROXY-PORT>",>
  "https_proxy": "http://<PROXY-SERVER-IP:<PROXY-PORT>",>
  "no_proxy": <"paste list from Configuring the cluster section">
"proxy": {
  "enabled": true,
Adding URLs to an allowlist
URLs for EKS and AKS
.microsoft.com
login.microsoftonline.com
login.windows.net
graph.microsoft.com
sfbrprddeploywe.azurecr.io
sfbrprddeploywe.westeurope.data.azurecr.io
registry-data.uipath.com
registry.uipath.com
dc.services.visualstudio.com
activate.uipath.com
download.uipath.com
du-metering.uipath.com
du.uipath.com
du-au.uipath.com
du-ca.uipath.com
du-jp.uipath.com
du-us.uipath.com
du-sg.uipath.com
raw.githubusercontent.com
objects.githubusercontent.com
pkg-containers.githubusercontent.com
raw.github.com
api.github.com
api.nuget.org
pkgs.dev.azure.com
gallery.uipath.com
github.com
pypi.org
pypi.python.org
pythonhosted.org
files.pythonhosted.org
opensuse.org
copr.fedorainfracloud.org
download.copr.fedorainfracloud.org
ping.looker.com
rt.services.visualstudio.com
uipath.pkgs.visualstudio.com
.blob.core.windows.net
pkgs.dev.azure.com
in.applicationinsights.azure.com
.pkg.dev
production.cloudflare.docker.com
.googleapis.com
.queue.core.windows.net
.openai.azure.com
.cognitiveservices.azure.com
api.openai.com
.amazonaws.com
.googleapis.com
.microsoft.com
login.windows.net
graph.microsoft.com
registry.uipath.com
activate.uipath.com
download.uipath.com
du.uipath.com
du-au.uipath.com
du-ca.uipath.com
du-jp.uipath.com
du-us.uipath.com
du-sg.uipath.com
raw.github.com
api.github.com
api.nuget.org
pkgs.dev.azure.com
gallery.uipath.com
github.com
pypi.org
pypi.python.org
pythonhosted.org
opensuse.org
ping.looker.com
pkgs.dev.azure.com
.pkg.dev
.googleapis.com
.openai.azure.com
api.openai.com
.amazonaws.com
.googleapis.com
Additional URLs for EKS
.s3.dualstack.CLOUD_REGION.amazonaws.com
public.ecr.aws
.cloudfront.net
sqs.CLOUD_REGION.amazonaws.com
public.ecr.aws
.cloudfront.net
Connector domains for Integration Service
To create a connection to Integration Service connectors and allow data traffic from your cluster to connector domains, you must configure an allowlist for connector domains.
Refer to Configuring an allowlist for connector domains for the full list of URLs.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
