Setting up Kerberos authentication with basic MSSQL authentication for Process Mining
Configure Kerberos authentication for Process Mining SQL database on EKS/AKS.
Note:
When you are performing a new installation and you want to use Kerberos authentication, it is strongly recommended to configure process app security as single_account. For details, refer to Configuring process app security.
When you want to use Kerberos authentication for login to Automation Suite and use basic MSSQL authentication for Process Mining you need to add the following in the processmining section in the input.json file.
"kerberos_auth_config": {
      "enabled": false
      "enabled": false
The following example shows a complete processmining section with Kerberos authentication with basic MSSQL and PostgreSQL authentication:
"processmining": {
    "enabled": true,
    "advanced_configuration": {},
    "airflow": {
      "metadata_db_connection_str": "postgresql+psycopg2://kerberos_user:@kerberospostgres.AUTOSUITEAD.LOCAL:5432/AutomationSuite_Airflow"
"processmining": {
    "enabled": true,
    "airflow": {
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
