Health endpoints
Health check endpoints for Automation Suite services on EKS/AKS.
To effectively monitor the health of your Automation Suite services, you can use the health endpoints listed in this section. These endpoints allow you to quickly verify if a service is operating correctly.
Platform​
  • https://<automation-suite-fqdn>/pap_/health
  • https://<automation-suite-fqdn>/pdp_/health
  • https://<automation-suite-fqdn>/identity_/.well-known/openid-configuration
  • https://<automation-suite-fqdn>/identity_/web/
  • https://<automation-suite-fqdn>/lease_/health/
  • https://<automation-suite-fqdn>/license_/health
  • https://<automation-suite-fqdn>/organization_/health
  • https://<automation-suite-fqdn>/portal_/portal/shallow/healthStatus
  • https://<automation-suite-fqdn>/audit_/health
  • https://<automation-suite-fqdn>/resourcecatalog_/health
Action Center​
  • https://<automation-suite-fqdn>/actions_/
  • https://<automation-suite-fqdn>/bupproxyservice_/health/ready
  • https://<automation-suite-fqdn>/processes_/
Agents​
  • https://<automation-suite-fqdn>/agents_/health
  • https://<automation-suite-fqdn>/agentsruntime_/health
AI Center​
  • https://<automation-suite-fqdn>/aifabric_/ai-app
  • https://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/ready
  • https://<automation-suite-fqdn>/aistorage_/health
  • https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Autopilot for Everyone​
  • https://<automation-suite-fqdn>/autopilotforeveryone_/api/health
Autopilot for Developers​
  • https://<automation-suite-fqdn>/autopilotstudio_/alive
  • https://<automation-suite-fqdn>/autopilotstudio_/health
Automation Hub​
  • https://<automation-suite-fqdn>/automationhub_/fd-api/v1/ping
  • https://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Solutions​
  • https://<automation-suite-fqdn>/automationsolutions_/health
Data Service​
  • https://<automation-suite-fqdn>/dataservice_/api/HealthCheck/health
  • https://<automation-suite-fqdn>/dataservice_/assets
Document Understanding​
  • https://<automation-suite-fqdn>/du_/api/documentmanager/health
  • https://<automation-suite-fqdn>/du_/api/storage/health
  • https://<automation-suite-fqdn>/du_/api/eventservice/health
  • https://<automation-suite-fqdn>/du_/metering/alive
  • https://<automation-suite-fqdn>/du_/ocr/info/ready
  • https://<automation-suite-fqdn>/du_/extended-ocr/ready
  • https://<automation-suite-fqdn>/du_/classify/MLclassification/info/ready
  • https://<automation-suite-fqdn>/du_/svc/formextractor/info
  • https://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Enterprise Context Service (ECS)​
  • https://<automation-suite-fqdn>/ecs_/health
Healing Agent (Semantic Proxy)​
  • https://<automation-suite-fqdn>/semanticproxy_/health
Insights​
  • https://<automation-suite-fqdn>/insights_/health
Integration Service​
  • https://<automation-suite-fqdn>/connections_/schedulerstatus
  • https://<automation-suite-fqdn>/connections_/dispatcherstatus
  • https://<automation-suite-fqdn>/elements_/v1/elements/health
  • https://<automation-suite-fqdn>/elements_/elements/api-v2/tickle
LLM Gateway​
  • https://<automation-suite-fqdn>/llmgateway_/health
LLM Observability​
  • https://<automation-suite-fqdn>/llmops_/health
  • https://<automation-suite-fqdn>/llmops_/tracesruntime/health
Maestro​
  • https://<automation-suite-fqdn>/pims_/api/health
Notification Service​
  • https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator​
  • https://<automation-suite-fqdn>/orchestrator_/api/health
Robotube​
  • https://<automation-suite-fqdn>/robotube_/healthz
ScreenPlay (Semantic Proxy)​
Studio Governance​
  • https://<automation-suite-fqdn>/roboticsops_/api/health
Studio Web​
  • https://<automation-suite-fqdn>/studio_/backend/healthz
  • https://<automation-suite-fqdn>/studio_/typecache/healthz/readiness
Test Manager​
  • https://<automation-suite-fqdn>/testmanager_/api/health/live
Checking service health​
To check the health of a specific service, send a request to its corresponding endpoint, as shown in the following example.
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
A successful response with an HTTP status code 200 indicates that the service is healthy.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
