Orchestrator advanced configuration
Advanced configuration options for Orchestrator in Automation Suite on EKS/AKS.
Advanced configuration allows support engineers to override specific service configuration parameters used during Automation Suite installation and deployment.
Using advanced configuration, you can:
  • Override resource requests and limits for deployments, stateful sets, and daemon sets.
  • Modify Horizontal Pod Autoscaler (HPA) settings.
  • Override specific Helm chart parameters used by services during installation.
All advanced configuration changes must be defined in the input.json file to ensure configuration consistency across environments.
Important:
Any configuration changes performed directly in ArgoCD must also be replicated in input.json. If the installer is re-run, changes made only in ArgoCD may be overwritten.
Using advanced configuration​
  1. Identify the parameters you want to override.
    You can locate these parameters in one of the following places:
    • The values.yaml file in the service Helm chart within the service-fabric-packaging repository.
    • The Parameters section of the corresponding application in ArgoCD.
    Example
    If the following parameter appears in the ArgoCD Parameters section:
    requests.cpu=10
    requests.cpu=10
    This corresponds to the following JSON configuration:
    "requests": {
      "cpu": "10"
    "requests": {
      "cpu": "10"
  2. Modify the input.json file.
    Add an advanced_configuration section under the corresponding service in input.json. Convert the parameter format from YAML to JSON before adding it to the file.
    The following example overrides resource parameters for the Orchestrator service:
      "orchestrator": {
        "advanced_configuration": {
          "requests": {
            "cpu": "100m",
            "memory": "100Mi",
            "storage": "1Gi",
            "gpu": 1
          "limits": {
            "cpu": "200m",
            "memory": "200Mi",
            "storage": "2Gi",
            "gpu": 1
      "orchestrator": {
          "requests": {
            "cpu": "100m",
            "memory": "100Mi",
            "storage": "1Gi",
            "gpu": 1
          "limits": {
            "cpu": "200m",
            "memory": "200Mi",
            "storage": "2Gi",
            "gpu": 1
  3. Update autoscaling parameters (optional).
    You can also override Horizontal Pod Autoscaler (HPA) parameters using the autoscaling configuration block.
      "orchestrator": {
          "autoscaling": {
            "minReplicas": 1,
            "maxReplicas": 3,
            "targetCPUUtilizationPercentage": 70,
            "targetMemoryUtilizationPercentage": 70,
            "scaleUpStabilizationWindowSeconds": 60,
            "scaleUp": {
              "policy": {
                "type": "Pods",
                "value": 1,
                "periodSeconds": 60
            "scaleDownStabilizationWindowSeconds": 60,
            "scaleDown": {
              "policy": {
                "type": "Pods",
                "value": 1,
                "periodSeconds": 60
      "orchestrator": {
          "autoscaling": {
            "minReplicas": 1,
            "maxReplicas": 3,
            "scaleUp": {
              "policy": {
                "type": "Pods",
                "value": 1,
                "periodSeconds": 60
            "scaleDown": {
              "policy": {
                "type": "Pods",
                "value": 1,
                "periodSeconds": 60
  4. Validate the changes.
    Before applying the configuration through the installer, you can optionally validate the parameters. To do this:
    • Modify the parameters directly in the ArgoCD application under the Parameters section.
    • Confirm the configuration behaves as expected.
    • Copy the validated configuration into the input.json file.
  • Using advanced configuration​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
