- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
- Provisioning Automation Suite Robots fails
- Health check of Automation Suite Robots fails
Solutions for Automation Suite Robots provisioning failures on AKS with Azure Files NFS.
The failure occurs mainly on FIPS enabled nodes when using Azure Files with the NFS protocol.
During the Automation Suite on AKS installation, creating the PVC for Automation Suite Robots asrobots-pvc-package-cache fails.
Potential issue
This happens because the AKS cluster cannot connect to Azure Files.
For example, the following error message may be displayed:
failed to provision volume with StorageClass "azurefile-csi-nfs": rpc error: code = Internal desc = update service endpoints failed with error: failed to get the subnet ci-asaks4421698 under vnet ci-asaks4421698: &{false 403 0001-01-01 00:00:00 +0000 UTC {"error":{"code":"AuthorizationFailed","message":"The client '4c200854-2a79-4893-9432-3111795beea0' with object id '4c200854-2a79-4893-9432-3111795beea0' does not have authorization to perform action 'Microsoft.Network/virtualNetworks/subnets/read' over scope '/subscriptions/64fdac10-935b-40e6-bf28-f7dc093f7f76/resourceGroups/ci-asaks4421698/providers/Microsoft.Network/virtualNetworks/ci-asaks4421698/subnets/ci-asaks4421698' or the scope is invalid. If access was recently granted, please refresh your credentials."}}}
Solution
To overcome this issue, you need to grant Automation Suite access to the Azure resource
- In Azure, navigate to the AKS resource group, then open the desired virtual network page. For example, in this case, the virtual network is
ci-asaks4421698. - From the Subnets list, select the desired subnet. For example, in this case, the subnet is
ci-asaks4421698. - At the top of the subnets list, select Manage Users. The Access Control page opens.
- Select Add role assignment.
- Search for the Network Contributor role.
- Select Managed Identity.
- Switch to theMembers tab.
- Select Managed Identity, then select Kubernetes Service.
- Select the name of the AKS cluster.
- Select Review and Assign.
