- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Last updated Dec 5, 2025
Orchestrator loads the following extensions by default, so you do not need to include them in the folder or the NLog configuration:
NLog.Targets.ElasticSearchUiPath.Orchestrator.Logs.ElasticsearchMicrosoft.ApplicationInsights.NLogTargetNLog.Extensions.AzureEventHub
Only Linux-compatible extensions can be used in this setup, so make sure that your chosen NLog extension abides by this rule.
To make the extension available for use, it must uploaded to the cluster storage. The
uipathctl command line tool can do this via the uipathctl config orchestrator upload command:
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/extensions/directoryuipathctl config orchestrator upload --nlog-extensions-directory /path/to/extensions/directoryIf you use an external storage configuration at the cluster level, you must indicate this by including the
--is-external-storage parameter.
Creating the advanced NLog configuration
Updating the advanced NLog configuration
The
uipathctl commands needed for updating the NLog configuration are:
uipathctl config orchestrator get-config --nlog-config- This exports the current configuration in a key-value pair json file, ready for editing.You can read more about it .
uipathctl config orchestrator update-config --nlog-config nlog.config.json- This updates the configuration with your changes.You can read more about it .
