How to uninstall Cert Manager
Uninstall Cert Manager from Automation Suite on EKS/AKS.
Prerequisites​
  • Kubectl CLI (kubectl) installed and configured.
  • Appropriate permissions to delete resources in the target namespaces.
Information required​
Before proceeding, you must gather the following information:
  • UiPath namespace where cert-manager resources are being used.
Step-by-step uninstallation process​
  1. Delete the role bindings for cert-manager:
    # Verify if the role binding exists
    kubectl get rolebinding -n <uipath_namespace> | grep cert-manager
    # If it exists, delete it
    kubectl delete rolebinding <role-binding-name> -n <uipath_namespace>
  2. Delete the cert-manager role:
    # Check if the role exists
    kubectl get role cert-manager -n <uipath_namespace> | grep cert-manager
    kubectl delete role <cert-manamger-role> -n <uipath_namespace>
  3. Clean up cert-manager resources in the namespace:
    # Delete all certificates
    kubectl delete certificates.cert-manager.io --all -n <uipath_namespace>
    # Delete all issuers
    kubectl delete issuers.cert-manager.io --all -n <uipath_namespace>
    # Delete all clusterissuers if you created any
    kubectl delete clusterissuers.cert-manager.io --all
  4. Uninstall the cert-manager from cluster, delete the namespace or any residual certificate resources following steps 1, 2, and 3 for other namespaces. Also, cross verify if cert-manager is not used by any other component.
  5. Verify remaining resources:
    # Check for any remaining cert-manager resources
    kubectl get all -n <uipath_namespace> | grep cert-manager
    kubectl get crd | grep cert-manager
Troubleshooting​
If certain resources cannot be deleted:
  • Ensure you have the necessary permissions.
  • Check if the resources are being used by other applications.
  • For resources that are stuck in Terminating state, you may need to remove finalizers.
Notes​
  • Only uninstall cert-manager if it is not being used by other applications in your cluster.
  • If multiple applications depend on cert-manager, consider only removing the UiPath-specific resources.
  • Replace <uipath_namespace> with your actual UiPath namespace.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
