- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Durable Execution Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Automation Suite products
UiPath product availability across Automation Suite deployment models and product dependencies on EKS/AKS.
Automation Suite lets you manage your self-hosted UiPath® platform as one product. However, not all of our self-hosted products are part of Automation Suite.
You can enable or disable products at any time after you install them.
The following table shows which Automation Suite products are available across deployment models.
| Product/Component | Linux | AKS | EKS | OpenShift |
| Action Center (Actions and Processes) | ✅ | ✅ | ✅ | ✅ |
| Agent Builder / Agents1 | ❌ | ✅ | ✅ | ✅ |
| Agent Hub1 | ❌ | ✅ | ✅ | ✅ |
| AI Center2 | ✅ | ✅ | ✅ | ✅ |
| AI Computer Vision | ✅ | ✅ | ✅ | ✅ |
| API Workflow1 | ❌ | ✅ | ✅ | ✅ |
| Apps | ✅ | ✅ | ✅ | ✅ |
| Automation Hub | ✅ | ✅ | ✅ | ✅ |
| Automation Ops | ✅ | ✅ | ✅ | ✅ |
| Automation Suite Robots | ✅ | ✅ | ✅ | ✅ |
| Autopilot for Developers (A4D)1 | ❌ | ✅ | ✅ | ✅ |
| Autopilot for Everyone | ❌ | ✅ | ✅ | ✅ |
| Autopilot for Testers | ❌ | ✅ | ✅ | ✅ |
| Coded Agent1 | ❌ | ✅ | ✅ | ✅ |
| Data Service | ✅ | ✅ | ✅ | ✅ |
| Document Understanding | ✅ | ✅ | ✅ | ✅ |
| ECS (Context Grounding) | ❌ | ✅ | ✅ | ✅ |
| GenAI Activities | ❌ | ✅ | ✅ | ✅ |
| Healing Agent1 | ❌ | ✅ | ✅ | ✅ |
| Insights | ✅ | ✅ | ✅ | ✅ |
| Integration Service | ✅ | ✅ | ✅ | ✅ |
| LLM Gateway | ❌ | ✅ | ✅ | ✅ |
| LLM Observability | ❌ | ✅ | ✅ | ✅ |
| Maestro (Agentic Orchestration)1 | ❌ | ✅ | ✅ | ✅ |
| Orchestrator | ✅ | ✅ | ✅ | ✅ |
| Process Mining | ✅ | ✅ | ✅ | ✅ |
| Screenplay1 | ❌ | ✅ | ✅ | ✅ |
| Semantic Proxy1 | ❌ | ✅ | ✅ | ✅ |
| Solutions | ✅ | ✅ | ✅ | ✅ |
| Studio Web | ❌ | ✅ | ✅ | ✅ |
| Durable Execution Service1, 3 | ❌ | ✅ | ✅ | ✅ |
| Test Manager | ✅ | ✅ | ✅ | ✅ |
1 Available starting with Automation Suite 2.2510.2.
2 AI Center connected to an external Orchestrator is not supported.
3 Automatically enabled when Maestro is installed. No additional licensing is required.
Some Automation Suite products have additional dependencies on each other, as listed in the following table:
| Product | Dependency |
| Agents |
| Apps |
| Automation Hub |
As Task Mining is not available in Automation Suite, the Automation Hub integration with Task Mining is also not available. |
| Autopilot for developers |
| Context Grounding (ECS) |
| Healing Agent |
| LLM Gateway |
| LLM Observability |
| Maestro |
| Process Mining |
| ScreenPlay |
| Solutions |
| Studio Web |
