- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Download Automation Suite installation packages and artifacts.
You must install the following software on your management machine. Management machine refers to the machine you use to operate your cluster and that can access your cluster via the kubeconfig file. Your management machine can run Linux, Windows, or macOS.
The following tools are required to successfully run the prerequisite checks, installation, and post-installation steps on your cluster via the client machine.
| Tool | Description | Download |
uipathctl | Required. A UiPath® command-line tool that allows you to run commands against Automation Suite Kubernetes. You can use it to check prerequisites in your environment, install Automation Suite, configure and manage it from a single unified CLI. For details, including a complete list of operations, refer to the uipathctl Reference Guide. | Download uipathctl |
versions.json | Required. Required to perform prerequisite checks and installation steps. | Download versions.json |
kubectl | Optional. Ensure that it matches the version of your cluster. | Download kubectl |
helm | Optional. Required for offline installations when configuring an OCI-compliant registry using mirror-registry.sh or hydrate-registry.sh. Helm 3.8 or later is required. | Download helm |
as-cmk.tar.gz | Contains the container images and deployment manifests of UiPath® shared capabilities and products. | Download as-cmk.tar.gz |
mirror-registry.sh | Required to configure an external Docker registry. | Download mirror-registry.sh |
hydrate-registry.sh | Required to configure the external OCI-compliant registry for offline installations. | Download hydrate-registry.sh |
as-images.txt | Contains the name and version of the container images that you must pull and upload into the external Docker registry. | Download as-images.txt |
as-helm-charts.txt | Contains the details for the UiPath® application helm chart that you must pull and upload to an external Docker registry hosted on your environment. | Download as-helm-charts.txt |
uipathtools | A CLI tool that contains a subset of uipathctl capabilities specific to health commands. | Download uipathtools |
cv-ondemand.tar.gz | Contains Computer Vision models and packages. | Download cv-ondemand.tar.gz |
This page provides a list of download links for all the artifacts you may need to install or configure Automation Suite. Make sure to select the version of the artifacts you target.
uipathctl
Required. uipathctl is a UiPath® command-line tool that allows you to run commands against Automation Suite. You can use uipathctl to check prerequisites in your environment, install Automation Suite, configure and manage it from a single unified CLI.
Currently, uipathctl is only compatible with the x86 architecture. You cannot run uipathctl on machines based on the ARM architecture, such as Macs with Apple Silicon (M series) CPUs.
2.2510.4
To download uipathctl for Automation Suite 2.2510.4, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathctl-2.2510.4-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathctl-2.2510.4-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathctl-2.2510.4-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathctl-2.2510.4-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathctl-2.2510.4-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathctl-2.2510.4-darwin-amd64.tar.gz
2.2510.3
To download uipathctl for Automation Suite 2.2510.3, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathctl-2.2510.3-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathctl-2.2510.3-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathctl-2.2510.3-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathctl-2.2510.3-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathctl-2.2510.3-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathctl-2.2510.3-darwin-amd64.tar.gz
2.2510.2
To download uipathctl for Automation Suite 2.2510.2, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathctl-2.2510.2-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathctl-2.2510.2-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathctl-2.2510.2-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathctl-2.2510.2-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathctl-2.2510.2-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathctl-2.2510.2-darwin-amd64.tar.gz
2.2510.1
To download uipathctl for Automation Suite 2.2510.1, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathctl-2.2510.1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathctl-2.2510.1-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathctl-2.2510.1-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathctl-2.2510.1-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathctl-2.2510.1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathctl-2.2510.1-darwin-amd64.tar.gz
2.2510.0
To download uipathctl for Automation Suite 2.2510.0, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathctl-2.2510.0-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathctl-2.2510.0-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathctl-2.2510.0-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathctl-2.2510.0-windows-amd64.tar.gz - macOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathctl-2.2510.0-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathctl-2.2510.0-darwin-amd64.tar.gz
versions.json
Required. Needed to perform prerequisite checks and installation steps.
2.2510.4
To download versions.json for Automation Suite 2.2510.4, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.4/versions.json
2.2510.3
To download versions.json for Automation Suite 2.2510.3, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.3/versions.json
2.2510.2
To download versions.json for Automation Suite 2.2510.2, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.2/versions.json
2.2510.1
To download versions.json for Automation Suite 2.2510.1, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.1/versions.json
2.2510.0
To download versions.json for Automation Suite 2.2510.0, run the following command:
wget -O ~/versions.json https://download.uipath.com/automation-suite/2.2510.0/versions.json
kubectl
Optional. Make sure that kubectl matches the version of your cluster.
To download kubectl, refer to Kubernetes documentation.
helm
Optional. Required for offline installations when configuring an OCI-compliant registry. Helm 3.8 or later is required.
To download helm, refer to the Helm documentation.
as-cmk.tar.gz
as-cmk.tar.gz contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product.
If you opt for the offline installation profile, you must download as-cmk.tar.gz. If you choose the online installation profile, Kubernetes will pull all the container images and deployment manifests directly from the container registry hosted in UiPath® servers.
as-cmk.tar.gz is required during installation and upgrade.
2.2510.4
https://download.uipath.com/automation-suite/2.2510.4/as-cmk-2.2510.4.tar.gz
For the checksum file, use the following URL: https://download.uipath.com/automation-suite/2.2510.4/as-cmk-2.2510.4-sha256sum.txt
Linux:
To download
as-cmk.tar.gzon a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.4/as-cmk-2.2510.4.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.4/as-cmk-2.2510.4.tar.gz -
Windows:
On a Windows machine, open the URL in your browser to download the file, then rename it to
as-cmk.tar.gz.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/as-cmk-2.2510.3.tar.gz
For the checksum file, use the following URL: https://download.uipath.com/automation-suite/2.2510.3/as-cmk-2.2510.3-sha256sum.txt
Linux:
To download
as-cmk.tar.gzon a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.3/as-cmk-2.2510.3.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.3/as-cmk-2.2510.3.tar.gz -
Windows:
as-cmk.tar.gz.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/as-cmk-2.2510.2.tar.gz
For the checksum file, download as-cmk-2.2510.2-sha256sum.txt.
Linux:
To download
as-cmk.tar.gzon a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.2/as-cmk-2.2510.2.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.2/as-cmk-2.2510.2.tar.gz -
Windows:
On a Windows machine, download as-cmk-2.2510.2.tar.gz and rename it to
as-cmk.tar.gz.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/as-cmk-2.2510.1.tar.gz
For the checksum file, download as-cmk-2.2510.1-sha256sum.txt.
Linux:
To download
as-cmk.tar.gzon a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.1/as-cmk-2.2510.1.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.1/as-cmk-2.2510.1.tar.gz -
Windows:
On a Windows machine, download as-cmk-2.2510.1.tar.gz and rename it to
as-cmk.tar.gz.
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/as-cmk-2.2510.0.tar.gz
For the checksum file, download as-cmk-2.2510.0-sha256sum.txt.
Linux:
To download
as-cmk.tar.gzon a Linux machine, run the following command:wget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.0/as-cmk-2.2510.0.tar.gzwget -O ~/as-cmk.tar.gz https://download.uipath.com/automation-suite/2.2510.0/as-cmk-2.2510.0.tar.gz -
Windows:
On a Windows machine, download as-cmk-2.2510.0.tar.gz and rename it to
as-cmk.tar.gz.
mirror-registry.sh
mirror-registry.sh is required to configure an external Docker registry.
2.2510.4
https://download.uipath.com/automation-suite/2.2510.4/mirror-registry.sh
Linux:
To download
mirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.4/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.4/mirror-registry.sh -
Windows:
On a Windows machine, open the URL in your browser to download the file.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/mirror-registry.sh
Linux:
To download
mirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.3/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.3/mirror-registry.sh -
Windows:
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/mirror-registry.sh
Linux:
To download
mirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.2/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.2/mirror-registry.sh -
Windows:
On a Windows machine, download mirror-registry.sh.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/mirror-registry.sh
Linux:
To download
mirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.1/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.1/mirror-registry.sh -
Windows:
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/mirror-registry.sh
Linux:
To download
mirror-registry.shon a Linux machine, run the following command:wget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.0/mirror-registry.shwget -O ~/mirror-registry.sh https://download.uipath.com/automation-suite/2.2510.0/mirror-registry.sh -
Windows:
hydrate-registry.sh
hydrate-registry.sh is required for configuring your external OCI-compliant registry for offline installations in the Automation Suite.
2.2510.4
Linux:
To download
hydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.4/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.4/hydrate-registry.sh -
Windows:
2.2510.3
Linux:
To download
hydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.3/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.3/hydrate-registry.sh -
Windows:
2.2510.2
Linux:
To download
hydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.2/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.2/hydrate-registry.sh -
Windows:
On a Windows machine, download hydrate-registry.sh.
2.2510.1
Linux:
To download
hydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.1/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.1/hydrate-registry.sh -
Windows:
2.2510.0
Linux:
To download
hydrate-registry.shon a Linux machine, run the following command:wget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.0/hydrate-registry.shwget -O ~/hydrate-registry.sh https://download.uipath.com/automation-suite/2.2510.0/hydrate-registry.sh -
Windows:
as-images.txt
as-images.txt contains the name and version of the container images that must be pulled and uploaded into the external Docker registry.
2.2510.4
https://download.uipath.com/automation-suite/2.2510.4/air-images.txt
Linux:
To download
air-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.4/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.4/air-images.txt -
Windows:
as-images.txt.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/air-images.txt
Linux:
To download
air-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.3/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.3/air-images.txt -
Windows:
as-images.txt.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/air-images.txt
Linux:
To download
air-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.2/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.2/air-images.txt -
Windows:
To download
air-images.txton a Windows machine, access this link and rename the file toas-images.txt.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/air-images.txt
Linux:
To download
air-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.1/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.1/air-images.txt -
Windows:
To download
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/air-images.txt
Linux:
To download
air-images.txton a Linux machine, run the following command:wget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.0/air-images.txtwget -O ~/as-images.txt https://download.uipath.com/automation-suite/2.2510.0/air-images.txt -
Windows:
To download
as-helm-charts.txt
as-helm-charts.txt contain the details for the UiPath® application helm chart that must be pulled and uploaded to an external Docker registry hosted on your environment.
2.2510.4
https://download.uipath.com/automation-suite/2.2510.4/embedded-helm-charts.txt
Linux:
To download
embedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.4/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.4/embedded-helm-charts.txt -
Windows:
as-helm-charts.txt.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/embedded-helm-charts.txt
Linux:
To download
embedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.3/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.3/embedded-helm-charts.txt -
Windows:
as-helm-charts.txt.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/embedded-helm-charts.txt
Linux:
To download
embedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.2/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.2/embedded-helm-charts.txt -
Windows:
On a Windows machine, download embedded-helm-charts.txt and rename it to
as-helm-charts.txt.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/embedded-helm-charts.txt
Linux:
To download
embedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.1/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.1/embedded-helm-charts.txt -
Windows:
as-helm-charts.txt.
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/embedded-helm-charts.txt
Linux:
To download
embedded-helm-charts.txton a Linux machine, run the following command:wget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.0/embedded-helm-charts.txtwget -O ~/as-helm-charts.txt https://download.uipath.com/automation-suite/2.2510.0/embedded-helm-charts.txt -
Windows:
as-helm-charts.txt.
uipathtools
uipathtools is a CLI tool that contains a subset of uipathctl capabilities specific to health commands. The tool is backward compatible and works with any supported Automation Suite version. We recommend using uipathtools as the first step if you face any issue.
2.2510.4
To download uipathtools, run one of the following commands, depending on your OS:
- Linux:
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathtools-2.2510.4-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathtools-2.2510.4-linux-amd64.tar.gz - Windows:
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathtools-2.2510.4-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathtools-2.2510.4-windows-amd64.tar.gz - macOS:
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathtools-2.2510.4-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.4/uipathtools-2.2510.4-darwin-amd64.tar.gz
2.2510.3
- Linux:
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathtools-2.2510.3-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathtools-2.2510.3-linux-amd64.tar.gz - Windows:
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathtools-2.2510.3-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathtools-2.2510.3-windows-amd64.tar.gz - macOS:
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathtools-2.2510.3-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.3/uipathtools-2.2510.3-darwin-amd64.tar.gz
2.2510.2
- Linux:
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathtools-2.2510.2-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathtools-2.2510.2-linux-amd64.tar.gz - Windows:
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathtools-2.2510.2-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathtools-2.2510.2-windows-amd64.tar.gz - macOS:
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathtools-2.2510.2-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.2/uipathtools-2.2510.2-darwin-amd64.tar.gz
2.2510.1
- Linux:
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathtools-2.2510.1-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathtools-2.2510.1-linux-amd64.tar.gz - Windows:
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathtools-2.2510.1-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathtools-2.2510.1-windows-amd64.tar.gz - macOS:
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathtools-2.2510.1-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.1/uipathtools-2.2510.1-darwin-amd64.tar.gz
2.2510.0
- Linux:
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathtools-2.2510.0-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathtools-2.2510.0-linux-amd64.tar.gz - Windows:
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathtools-2.2510.0-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathtools-2.2510.0-windows-amd64.tar.gz - macOS:
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathtools-2.2510.0-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2.2510.0/uipathtools-2.2510.0-darwin-amd64.tar.gz
cv-ondemand.tar.gz
cv-ondemand.tar.gz contains Computer Vision models and packages.
If you opt for the offline installation profile, you must download cv-ondemand.tar.gz. If you choose the online installation profile, Automation Suite will pull all the Computer Vision models directly from the container registry hosted in UiPath® servers.
cv-ondemand.tar.gz is required only when you want to use Computer Vision models.
2.2510.4
https://download.uipath.com/automation-suite/2.2510.4/cv2510-2.2510.4.tar.gz
For the checksum file, use the following URL: https://download.uipath.com/automation-suite/2.2510.4/cv2510-2.2510.4-sha256sum.txt
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.4/cv2510-2.2510.4.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.4/cv2510-2.2510.4.tar.gz -
Windows:
cv-ondemand.tar.gz.
2.2510.3
https://download.uipath.com/automation-suite/2.2510.3/cv2510-2.2510.3.tar.gz
For the checksum file, use the following URL: https://download.uipath.com/automation-suite/2.2510.3/cv2510-2.2510.3-sha256sum.txt
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.3/cv2510-2.2510.3.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.3/cv2510-2.2510.3.tar.gz -
Windows:
cv-ondemand.tar.gz.
2.2510.2
https://download.uipath.com/automation-suite/2.2510.2/cv2510-2.2510.2.tar.gz
For the checksum file, download cv2510-2.2510.2-sha256sum.txt.
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.2/cv2510-2.2510.2.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.2/cv2510-2.2510.2.tar.gz -
Windows:
On a Windows machine, download cv2510-2.2510.2.tar.gz and rename it to
cv-ondemand.tar.gz.
2.2510.1
https://download.uipath.com/automation-suite/2.2510.1/cv2510-2.2510.1.tar.gz
For the checksum file, download cv2510-2.2510.1-sha256sum.txt.
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.1/cv2510-2.2510.1.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.1/cv2510-2.2510.1.tar.gz -
Windows:
On a Windows machine, download cv2510-2.2510.1.tar.gz and rename it to
cv-ondemand.tar.gz.
2.2510.0
https://download.uipath.com/automation-suite/2.2510.0/cv2510-2.2510.0.tar.gz
For the checksum file, download cv2510-2.2510.0-sha256sum.txt.
Linux:
To download
cv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.0/cv2510-2.2510.0.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.0/cv2510-2.2510.0.tar.gz -
Windows:
On a Windows machine, download cv2510-2.2510.0.tar.gz and rename it to
cv-ondemand.tar.gz.
- uipathctl
- 2.2510.4
- 2.2510.3
- 2.2510.2
- 2.2510.1
- 2.2510.0
- versions.json
- 2.2510.4
- 2.2510.3
- 2.2510.2
- 2.2510.1
- 2.2510.0
- kubectl
- helm
- as-cmk.tar.gz
- 2.2510.4
- 2.2510.3
- 2.2510.2
- 2.2510.1
- 2.2510.0
- mirror-registry.sh
- 2.2510.4
- 2.2510.3
- 2.2510.2
- 2.2510.1
- 2.2510.0
- hydrate-registry.sh
- 2.2510.4
- 2.2510.3
- 2.2510.2
- 2.2510.1
- 2.2510.0
- as-images.txt
- 2.2510.4
- 2.2510.3
- 2.2510.2
- 2.2510.1
- 2.2510.0
- as-helm-charts.txt
- 2.2510.4
- 2.2510.3
- 2.2510.2
- 2.2510.1
- 2.2510.0
- uipathtools
- 2.2510.4
- 2.2510.3
- 2.2510.2
- 2.2510.1
- 2.2510.0
- cv-ondemand.tar.gz
- 2.2510.4
- 2.2510.3
- 2.2510.2
- 2.2510.1
- 2.2510.0
