- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Configure per-tenant encryption keys using Azure Key Vault in Orchestrator on EKS/AKS.
To configure the encryption key per tenant, take the following steps:
Update the Orchestrator parameters. In the configuration file, under
orchestrator, add theencryption_key_per_tenantsection. For details, refer to Configuring Orchestrator parameters."orchestrator": { "enabled": true, "encryption_key_per_tenant": { "certificate_base_64": "", "certificate_password": "", "client_id": "", "directory_id": "", "vault_address": "" } }"orchestrator": { "enabled": true, "encryption_key_per_tenant": { "certificate_base_64": "", "certificate_password": "", "client_id": "", "directory_id": "", "vault_address": "" } }You must convert the certificate to base64 before using it as a parameter override. To do that, run the following command:
- PowerShell
[convert]::ToBase64String((Get-Content -path "path_to_certificate" -Encoding byte))[convert]::ToBase64String((Get-Content -path "path_to_certificate" -Encoding byte)) - Shell
base64 [_path_to_certificate_]base64 [_path_to_certificate_]
- PowerShell
Apply the new configuration, and then wait for the Orchestrator ArgoCD app to synchronize.
Enable the EncryptionKeyPerTenant feature by setting the following keys in
appSettings:"EncryptionKeyPerTenant.Enabled": "true", "EncryptionKeyPerTenant.KeyProvider": "AzureKeyVault","EncryptionKeyPerTenant.Enabled": "true", "EncryptionKeyPerTenant.KeyProvider": "AzureKeyVault",For more on updating
appSettings, refer to Configuring appSettings.Note:SMTP settings in Identity Server are not encrypted with the per-tenant key. After enabling encryption key per tenant, make sure to re-enter the SMTP password in the Automation Suite portal.
