- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Solutions for Velero backup failures when connecting to Azure Government in Automation Suite on AKS.
Following an Automation Suite on AKS installation or upgrade, the backup setup does not work because of a failure to connect to Azure Government.
Solution
You can fix the issue by taking the following steps:
- Create a file named
velerosecrets.txt, with the following contents:AZURE_CLIENT_SECRET=<secretforserviceprincipal> AZURE_CLIENT_ID=<clientidforserviceprincipal> AZURE_TENANT_ID=<tenantidforserviceprincipal> AZURE_SUBSCRIPTION_ID=<subscriptionidforserviceprincipal> AZURE_CLOUD_NAME=AzureUSGovernmentCloud AZURE_RESOURCE_GROUP=<infraresourcegroupoftheakscluster>AZURE_CLIENT_SECRET=<secretforserviceprincipal> AZURE_CLIENT_ID=<clientidforserviceprincipal> AZURE_TENANT_ID=<tenantidforserviceprincipal> AZURE_SUBSCRIPTION_ID=<subscriptionidforserviceprincipal> AZURE_CLOUD_NAME=AzureUSGovernmentCloud AZURE_RESOURCE_GROUP=<infraresourcegroupoftheakscluster> - Encode the data in the
velerosecrets.txtfile as Base64:export b64velerodata=$(cat velerosecrets.txt | base64)export b64velerodata=$(cat velerosecrets.txt | base64) - Update the
velero-azuresecret in theveleronamespace, as shown in the following example:apiVersion: v1 kind: Secret metadata: name: velero-azure namespace: velero data: cloud: <insert the $b64velerodata value here>apiVersion: v1 kind: Secret metadata: name: velero-azure namespace: velero data: cloud: <insert the $b64velerodata value here> - Restart the
velerodeployment:kubectl rollout restart deploy -n velerokubectl rollout restart deploy -n velero
