TLS certificate validation errors
Solutions for TLS certificate validation errors in Automation Suite on EKS/AKS.
If TLS certificate validation fails after updating the certificates in Automation Suite, refer to the following table to identify the cause and resolution.
Error message (contains)CauseResolution
incomplete or untrusted certificate chainA missing intermediate certificate, or the chain does not lead to the provided root CA.Put all intermediate certificates and the root CA in ca.crt.
is not part of the leaf certificate's chainA certificate that did not issue the leaf is present (a sibling or unrelated intermediate, or a duplicate).Ensure server.crt contains only the certificates from the leaf's actual signing chain - remove any sibling, unrelated, or duplicate CA certificates. Put the signing chain's intermediate(s) and root CA in ca.crt.
certificates are not in the correct orderCertificates are out of order.Order them: leaf certificate, then intermediate(s), then root CA.
leaf certificate does not match fqdnThe leaf certificate's SAN omits the cluster FQDN, or server.crt does not start with the leaf.Ensure server.crt begins with the leaf certificate and that the cluster FQDN is listed in its Subject Alternative Names.
Certificate requirements​
To ensure TLS certificate validation succeeds, ensure the certificate files meet the following requirements:
  • The server.crt file must contain the complete public server certificate chain in PEM format. The chain must start with the leaf server certificate, followed by the intermediate CA certificate(s), and then the root CA that form the signing path for that leaf certificate.
  • The server.crt file must include only certificates that are part of the leaf certificate's actual signing chain. Do not include sibling, unrelated, duplicate, or alternate CA certificates, as TLS validation fails when certificates outside the leaf certificate's chain are present.
  • The ca.crt file must contain the CA certificate bundle used to validate the server certificate chain, including the required intermediate CA certificate(s) and root CA. The ca.crt file must not include the leaf server certificate.
  • Certificate requirements​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
