- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Upgrade fails due to overridden Insights PVC sizes
Solutions for upgrade failures due to Insights PVC size overrides in Automation Suite on EKS/AKS.
The upgrade can fail due to an issue where existing insights PVC sizes get overridden during the process. This issue occures due to unexpected changes to the PVC sizes that are not correctly reflected during the upgrade.
Solution
To address the problem, you must manually change the PVC sizes in ArgoCD UI:
In the ArgoCU UI, select Insights.
From the upper-left corner, select the Details button and then select the Parameters tab.
From the upper-right corner, select the Edit button and update the
sizeparameter underinsightslooker.insightslooker.persistenceaccording to your deployed PVC size.- To retrieve the correct size of
insights-looker-lookerdir-pvc, run the following command:kubectl get pvc -n uipath insights-looker-lookerdir-pvc -o json |jq -r .status.capacity.storagekubectl get pvc -n uipath insights-looker-lookerdir-pvc -o json |jq -r .status.capacity.storage - To retrieve the correct size of
insights-looker-datadir-pvc, run the following command:kubectl get pvc -n uipath insights-looker-datadir-pvc -o json |jq -r .status.capacity.storagekubectl get pvc -n uipath insights-looker-datadir-pvc -o json |jq -r .status.capacity.storage
After you update the VALUES field, select the SAVE button and sync Insights.
