- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Infrastructure and configuration prerequisites for Automation Suite on EKS/AKS.
The following table lists the main hardware and software requirements for deploying Automation Suite on EKS/AKS.
| Component | Prerequisites |
| Cluster | AKS or EKS cluster Refer to Kubernetes version. |
| Minimum node capacity | 8 vCPU and 16 GB RAM |
| Total cluster capacity | Refer to Capacity planning. |
| Cache | Redis |
| Registry | OCI-compliant registry required in offline installations. |
| SQL Server |
| Storage |
| Networking | Network policies, VNETs / VPCs, DNS, subnets, NSGs / security groups, NAT gateway, elastic IP and internet gateway |
| TLS | 1.2 or 1.3 |
| Certificates | The certificate for the FQDN to access Automation Suite. |
| Proxy | Only required for proxy configurations. |
