- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Increase maximum request size limits for Orchestrator and other services in Automation Suite on EKS/AKS.
You can configure the maximum request size in the orchestrator-customconfig config map using a tool such as kubectl.
For details, refer to Custom Orchestrator configuration.
The default value for the maximum request size is 300 MB, but you can edit it in the values.json file. The Orchestrator deployment should restart automatically after this configuration change.
"Kestrel": {
"Limits": {
"MaxRequestBodySize": 314572800
"Kestrel": {
"Limits": {
The values.json file in the orchestrator-customconfig config map may also contain other values, such as AppSettings. You must not remove any other settings when configuring the maximum request size.
"Kestrel": {
"AppSettings": {
"Kestrel": {
"AppSettings": {
