Configuring NGINX ingress controller
Configure NGINX ingress controller settings for Automation Suite on EKS/AKS.
In standard configuration, Automation Suite provisions a Load Balancer Kubernetes service type configured with Istio Gateway as an ingress controller for the requests coming from the network load balancer.
If you already have an NGINX ingress controller in your cluster and want to continue to use it, you must configure the Kubernetes service_type as cluster_IP instead of Load Balancer. This document provides the necessary changes required for that configuration.
Important:
To manage large headers, adjust the proxy-buffer-size in the ingress annotation as follows:
nginx.ingress.kubernetes.io/proxy-buffer-size: "8k"
NGINX to Istio via HTTP
Updating your NGINX ingress configuration
You must update your NGINX specification with istio-ingressgateway as a backend service and specify the port number 80. Additionally, if you have your own Network Policies, make sure they are configured correctly to allow NGINX and Istio routing.
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
  namespace: <istio-system>
spec:
  ingressClassName: nginx
  tls:
    - hosts:
        - "<FQDN>"
        - "*.<FQDN>"
      secretName: nginx-tls
  rules:
    - host: "<FQDN>"
      http:
        paths:
        - path: /
          pathType: Prefix
          backend:
            service:
              port:
                number: 80
    - host: "*.<FQDN>"
      http:
        paths:
        - path: /
          pathType: Prefix
          backend:
            service:
              port:
                number: 80
kind: Ingress
metadata:
spec:
  tls:
    - hosts:
        - "<FQDN>"
        - "*.<FQDN>"
  rules:
    - host: "<FQDN>"
      http:
        paths:
        - path: /
          pathType: Prefix
          backend:
            service:
              port:
                number: 80
    - host: "*.<FQDN>"
      http:
        paths:
        - path: /
          pathType: Prefix
          backend:
            service:
              port:
                number: 80
input.json parameters
You must provide the following parameters in input.json to change service_type and HTTPS:
"ingress": {
  "service_type": "ClusterIP",
  "HTTPS": false
"ingress": {
  "HTTPS": false
NGINX to Istio via HTTPs
Updating the NGINX ingress configuration
You must update your NGINX specification with istio-ingressgateway as a backend service and specify https as the port name.
kind: Ingress
metadata:
  annotations:
    nginx.ingress.kubernetes.io/backend-protocol: "https"
    nginx.ingress.kubernetes.io/proxy-ssl-name: "<FQDN>"
    nginx.ingress.kubernetes.io/proxy-ssl-server-name: "on"
    nginx.ingress.kubernetes.io/proxy-ssl-secret: "<istio-system>/istio-ingressgateway-certs"
    nginx.ingress.kubernetes.io/proxy-ssl-verify: "on"
spec:
  tls:
    - hosts:
        - "<FQDN>"
        - "*.<FQDN>"
  rules:
    - host: "<FQDN>"
      http:
        paths:
        - path: /
          pathType: Prefix
          backend:
            service:
              port:
    - host: "*.<FQDN>"
      http:
        paths:
        - path: /
          pathType: Prefix
          backend:
            service:
              port:
kind: Ingress
metadata:
  annotations:
spec:
  tls:
    - hosts:
        - "<FQDN>"
        - "*.<FQDN>"
  rules:
    - host: "<FQDN>"
      http:
        paths:
        - path: /
          pathType: Prefix
          backend:
            service:
              port:
    - host: "*.<FQDN>"
      http:
        paths:
        - path: /
          pathType: Prefix
          backend:
            service:
              port:
"ingress": {
  "HTTPS": true
"ingress": {
  "HTTPS": true
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
