- Overview
- Requirements
- Pre-installation
- Preparing the installation
- Granting installation permissions
- Installing the External Secrets Operator in Kubernetes
- Running uipathctl
- Migration and upgrade
- Monitoring and alerting
- Cluster administration
- Accessing the Models
- Enabling or disabling Extended Languages OCR
- Allocating GPU resources for Document Understanding modern projects
- Configuring appSettings
- Configuring NLog
- AI Trust Layer
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Velero backup fails with FailedValidation error
- External Secrets troubleshooting
- Temporal as a Service troubleshooting
- Fluentd does not export logs in IPv6 environments
Enable or disable extended language OCR support in Document Understanding on EKS/AKS.
To make sure you are eligible for Extended Language OCR in Automation Suite, reach out to your Account executive to understand the required commitments.
To use the Extended Languages OCR, you need to have a valid license configured. The license is a base64 string file provided by UiPath® over email. To obtain the license, file a support ticket under Document Understanding > Extended Languages OCR License Request.
Obtaining access to Extended Languages OCR involves acceptance of the following additional terms and conditions:
- Redistribution of the license by the user to other organizations is strictly prohibited. This license is specifically intended for the use of the Extended Languages OCR as part of UiPath Automation Suite, and solely by the entity to which it is provided.
- Users are obligated to submit usage reports every quarter, with deadlines on March 31st, June 30th, Sept 30th, and Dec 31st
each year. These reports can be produced by navigating to the
uipath-as-platformstorage container and compressing the folder pathaistorage/org-00000000-0000-0000-0000-000000000001/tenant-00000000-0000-0000-0000-000000000001into a zip file. This zip file is then sent to a UiPath email address that will be provided with the license file.
Non-compliance with these conditions will result in the inability to renew Extended OCR licenses.
The license file expires after 12 months, so a license renewal is needed every 12 months. There is a one month grace period, after which the container will cease processing requests.
After receiving the license string, continue with the steps from this procedure.
After installing or upgrading Automation Suite, configure the
input.jsonfile. -
Add the string for Extended Languages OCR in the
input.jsonfile.When receiving the license via email, open the license file with any text editor and copy and paste the string you find inside the
licenseproperty of thedocumentunderstandingobject.Note:Make sure that the contents of the file are in base64 format before moving to step 3. If not, convert the content to base64 format before moving to the next step.
If the
documentunderstandingobject is not yet configured, add it using the following configuration:"documentunderstanding": { "enabled": true, "extendedOcr": { "enabled": true, "license": "<base64 encoded license string goes here>" } },"documentunderstanding": { "enabled": true, "extendedOcr": { "enabled": true, "license": "<base64 encoded license string goes here>" } },Note:If the
documentunderstandingobject is already configured, copy only theextendedOcrproperty from the license file without changing any other properties. -
Execute the Automation Suite installer again using the following command:
uipathctl manifest apply input.json --versions versions.jsonuipathctl manifest apply input.json --versions versions.json -
Go to the ArgoCD panel, in the Document Understanding section and check if the Extended Languages OCR is displayed.
You can access the Extended Languages OCR using the following endpoint: {FQDN}/<organization_id>/<tenant_id>/du_/extended-ocr.
