Automation Hub
Banner background image
Automation Hub User Guide
Last updated Apr 16, 2024
Starting as a Citizen Developer Power User
After successfully logging in, you, as a Citizen Developer Power User can explore the list of Automations submitted for your tenant and get inspired.
You are encouraged to share automations created for tasks or processes performed by you or your team. The automations you submit should be made for low risk, simple/medium task/activities or processes and are addressed to users from your own department or team.
Besides sharing automations you can perform the development for selected automations. To do this access the Automation Pipeline page > Implementation > apply the Development Phase and Not Started Status filters and choose which automations you want to develop.
Within the Workspace Overview module, you can have a detailed view over:
