Verifying policy versions
Before creating a new policy, make sure you're using the latest policy versions for applications. Do this by following the steps below:
- In Automation Ops > Gouvernance, select Settings.
- Select a 22.10 or higher version for Studio or StudioX and select Save.
Creating a new product policy
To add a new product policy, follow the steps below:
- In Automation Ops > Governance, select Add Product Policy.
- Select Studio or StudioX, input a Name to your policy, and select Add.
Note:
If you want to enforce the analyzer, activate the Enforce Analyzer before Publish setting in the Design section.
- Select Workflow Analyzer tab and scroll down until you find the ST-USG-034 Rule ID.
- Select the Edit icon.
- Check the Is enabled box to activate the rule and select Save.
Deploying a policy rule
- In Automation Ops > Governance, select Deployment.
- In the Users tab, select the Edit icon beside your User Name.
- Make sure that for the Studio, the newly created policy is selected.
More information:
To learn more about governance deployment check Deploy Governance Policies article.
Note:
If you can't find your user in the list, select Deployment for User, to create one.
Below is a video representation of the process:
Updated 27 days ago
