2022.4
Automation Suite 安装指南
迁移先决条件
在开始迁移之前,请确保您满足以下先决条件:
.NET Runtime 6.0​
运行 UiPath.OrganizationMigrationApp 工具需要 .NET Runtime 6.0 或更高版本。 在运行 UiPath.OrganizationMigrationApp 之前,您必须下载并安装它。
Linux​
If .NET Runtime 6.0 or later is not present, download and install .NET Runtime for Linux before using UiPath.OrganizationMigrationApp.
要在 RHEL 上安装 .NET Runtime 6.0,请运行以下命令:
sudo yum install dotnet-sdk-6.0 -y
Windows​
The UiPath.OrganizationMigrationApp tool requires .NET Runtime 6.0 at a minimum. If .NET Runtime 6.0 and beyond is not present, download and install .NET Runtime 6.0 for Windows before using UiPath.OrganizationMigrationApp.
UiPath.OrganizationMigrationApp​
UiPath.OrganizationMigrationApp 工具可帮助您执行操作,例如将所有租户的身份数据从独立移动到 Automation Suite 以及合并组织。
To download UiPath.OrganizationMigrationApp, see Downloading the installation packages.
To see which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
用于管理 Microsoft SQL Server 的工具​
您必须下载并安装 SQL Server Management Studio (SSMS) 或类似工具才能管理 Microsoft SQL Server。 此工具可帮助您将 Orchestrator 数据库还原到 Automation Suite SQL Server 实例或其他 SQL Server 实例。
  1. 下载并安装 SQL Server Management Studio。
  2. 使用独立 SQL 连接字符串登录独立 SQL Server。
  3. 打开源数据库和目标数据库的端口 1433 。
连接字符串密码的特殊字符转义规则​
In most instances, connection passwords are encapsulated within a single quotation mark ('). However, when the password includes special characters such as ``` or $, a different approach is required.
In these cases, the password must be formatted as \"`", replacing ` with the actual password. Moreover, you must also adhere to the escape rules as detailed in the following table:
ADDU 中的原始格式PowerShell 字符串中的转义格式
cn=James $ Smith"cn=James $ Smith"`
cn=Sally Wilson + Jones"cn=Sally Wilson \+ Jones"
cn=William O'Brian"cn=William O'Brian"
cn=William OBrian`"cn=William O``Brian"
cn=Richard #West"cn=Richard #West"
cn=Roy Johnson$"cn=Roy Johnson$"
示例​
Assume that the original password is 7'8:<=XMe$y[@vC?_4ZeY8c-~y'W!1dU4gnczuf'/p>j<I. Adhering to the special character escape rules, it becomes: Password=\"7'8:<=XMe$y[@vC?_4ZeY8c-~y'W!1dU4```gnczuf'/p>```j<I\"`.
在目标连接字符串中配置了密码的完整命令如下所示:
./UiPath.OrganizationMigrationApp.exe migrate -a -m -s "Server=tcp:abc.com,1433;Initial Catalog=UiPath_20230531;Persist Security Info=False;User ID=username;Password=asiodhyf;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;" -d "Server=tcp:cde.net,1433;Initial Catalog=AutomationSuite_Platform;Persist Security Info=False;User Id=testadmin@sfdev3980732-sql.database.windows.net;Password=\`"7'8:<=XMe`$y[@vC?_4ZeY8c-~y'W!1dU4```gnczuf'/p>```j<I\`""
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
