2022.4
Automation Suite 安装指南
设置 Splunk
备注:
  • This section covers exporting POD logs. For exporting robot logs, see Ochestrator - About Logs.
  • Splunk is an external tool, and UiPath does not have an opinion on how you should configure your Splunk setting. For more details about HTTP Event Collector, see Splunk official documentation.
Splunk-Fluentd 堆栈是一个集中式日志记录解决方案,可用于搜索、分析和可视化日志数据。Fluentd 收集日志并将其发送到 Splunk。Splunk 会检索日志,并让您可视化和分析数据。
使用令牌创建密码​
要使用 Splunk 的 HTTP 事件收集器令牌在集群中创建密码,请运行以下命令:
kubectl -n cattle-logging-system create secret generic splunk-hec-token --from-literal=splunk_hec_token=<splunk_hec_token>
集群输出到 Splunk​
Run the following command to ClusterOutput to Splunk. Replace the following attributes with the ones used in your Splunk configuration:
kubectl -n cattle-logging-system apply -f - <<"EOF"
apiVersion: logging.banzaicloud.io/v1beta1
kind: ClusterOutput
metadata:
spec:
  splunkHec:
    buffer:
      tags: '[]'
      timekey: <splunk_hec_timekey>
      timekey_use_utc: true
      timekey_wait: 10s
      type: file
    hec_host: <splunk_hec_host>
    hec_port: <splunk_hec_port>
    hec_token:
      valueFrom:
        secretKeyRef:
          key: <secret_key>
    index: <splunk_hec_index>
    insecure_ssl: true
    protocol: <splunk_hec_protocol>
    source: <splunk_hec_source>
    sourcetype: <splunk_hec_source_type>
EOF
kind: ClusterOutput
metadata:
spec:
  splunkHec:
    buffer:
      tags: '[]'
      timekey_wait: 10s
      type: file
    hec_token:
      valueFrom:
        secretKeyRef:
          key: <secret_key>
    insecure_ssl: true
EOF
属性描述
splunk_hec_hostSplunk 实例的网络主机。
splunk_hec_port用于客户端通信的 Splunk 端口。
secret_key带有 Splunk 令牌的密钥。
splunk_hec_timekey 中的值 splunkHec.buffer输出频率,即您想要推送日志的频率。
protocolURL 协议。有效值为 http 和 https。
splunk_hec_index用于索引事件的 Splunk 索引标识符。
splunk_hec_source事件的来源字段。
splunk_hec_source_type事件的来源类型字段。
FluentD 中的集群流程​
Run the following command to ClusterFlow in Fluentd:
kind: ClusterFlow
metadata:
  namespace: cattle-logging-system
spec:
  filters:
  - tag_normaliser:
      format: ${namespace_name}/${pod_name}.${container_name}
  globalOutputRefs:
  - splunk-output
  match:
  - select:
      container_names:
      - istio-proxy
      namespaces:
      - istio-system
  - exclude:
      container_names:
      - istio-proxy
      - istio-init
      - aicenter-hit-count-update
      - istio-configure-executor
      - on-prem-tenant-license-update
      - curl
      - recovery
      - aicenter-oob-scheduler
      - cert-trustor
  - exclude:
      namespaces:
      - fleet-system
      - cattle-gatekeeper-system
      - default
  - exclude:
      labels:
        app: csi-snapshotter
  - exclude:
      labels:
        longhorn.io/job-task: backup
  - exclude:
      labels:
        app: csi-resizer
  - select: {}
EOF
kind: ClusterFlow
metadata:
spec:
  filters:
  - tag_normaliser:
  globalOutputRefs:
  - splunk-output
  match:
  - select:
      container_names:
      - istio-proxy
      namespaces:
      - istio-system
  - exclude:
      container_names:
      - istio-proxy
      - istio-init
      - curl
      - recovery
      - cert-trustor
  - exclude:
      namespaces:
      - fleet-system
      - default
  - exclude:
      labels:
  - exclude:
      labels:
  - exclude:
      labels:
        app: csi-resizer
  - select: {}
EOF
备注:
系统会收集集群中的日志并将其记录到 ClusterOutput 中。
配置 Splunk​
要配置 Splunk,请执行以下步骤:
  1. 单击顶部导航栏中的“设置”,然后选择“索引”。
  2. 单击“新建索引”,然后单击“创建索引”。
  3. 单击顶部导航栏中的“设置”,然后选择“数据输入”。
  4. 单击“HTTP 事件收集器”。
  5. 单击“全局设置”以准许创建新令牌。
  6. 启用并保存“全局设置”。
  7. 单击“新建令牌”以创建令牌。
  8. 输入 HTTP 事件收集器的名称,然后单击“下一步”。
  9. 单击“新建”并输入“来源类型”详细信息。
  10. 向下滚动并从可用索引列表中选择“索引”,然后单击顶部导航栏中的“下一步” 。
  11. 验证数据,然后单击“提交”。
  12. Once created, fetch the details of Token ID,Index,Source,Source Type. You will need these when setting up ClusterOutput.
在 Splunk 中搜索​
  1. 单击“搜索和报告”。
  2. Search based on Source,Index, and SourceType.
故障排除​
如果由于某种原因应用程序日志未推送到 Splunk,请尝试以下操作:
  1. 将 Fluentd 日志级别更改为调试
  2. 查询 Fluentd Pod:
    kubectl patch loggings.logging.banzaicloud.io rancher-logging-root --type=json -p '[{"op":"add","path":"/spec/fluentd/logLevel","value":debug}]'
    kubectl -n cattle-logging-system exec -it sts/rancher-logging-root-fluentd cat /fluentd/log/out
    备注:
    Fluentd 日志应指明数据未推送到 Splunk 的原因。
  3. 修复问题后,还原 FluentD 日志级别:
    kubectl patch loggings.logging.banzaicloud.io rancher-logging-root --type=json -p '[{"op":"remove","path":"/spec/fluentd/logLevel"}]'
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
