Automation Suite 安装指南
设置 Elasticsearch 和 Kibana
EFK(Elasticsearch、Fluentd、Kibana)堆栈是一个集中式日志记录解决方案,可用于搜索、分析和可视化日志数据。Fluentd 收集日志并将其发送到 Elasticsearch,Kibana 检索日志并让您可视化和分析数据。
Automation Suite 支持 Elasticsearch 版本 7.x。
使用 Elasticsearch 密码创建密码​
如果您的 Elasticsearch 实例需要凭据,请在集群中使用其密码创建一个密码。
kubectl -n cattle-logging-system create secret generic elastic-user --from-literal=password=<password>
集群输出到 Elasticsearch​
运行以下命令,将集群输出到 Elasticsearch。将以下属性替换为您的 Elasticsearch 配置:
  • <elasticsearch host> - Elasticsearch 实例的网络主机;
  • <elasticsearch port> - 用于客户端通信的 Elasticsearch 端口;
  • <secret key> - 包含 Elasticsearch 密码的密码;
  • elasticsearch.buffer 中的 timekey 值 - 输出频率,即您想要推送日志的频率;
  • elasticsearch.scheme - URL 方案。有效值为:http 或 https。
    kubectl -n cattle-logging-system apply -f - <<"EOF"
    apiVersion: logging.banzaicloud.io/v1beta1
    kind: ClusterOutput
    metadata:
    spec:
      elasticsearch:
        host: <elasticsearch host>
        port: <elasticsearch port>
        scheme: <http or https>
        ssl_verify: false
        ssl_version: TLSv1_2
        user: elastic
        password:
          valueFrom:
            secretKeyRef:
              key: <secret key>
        buffer:
          timekey: 10m
          timekey_wait: 30s
          timekey_use_utc: true
    EOF
    kind: ClusterOutput
    metadata:
    spec:
      elasticsearch:
        ssl_verify: false
        user: elastic
        password:
          valueFrom:
            secretKeyRef:
              key: <secret key>
        buffer:
          timekey: 10m
          timekey_wait: 30s
    EOF
FluentD 中的集群流程​
在 FluendD 中对集群流程运行以下命令:
kind: ClusterFlow
metadata:
spec:
  filters:
    - tag_normaliser:
        format: ${namespace_name}/${pod_name}.${container_name}
  globalOutputRefs:
    - es-output
  match:
    - select:
        container_names:
          - istio-proxy
        namespaces:
          - istio-system
    - exclude:
        container_names:
          - istio-proxy
          - istio-init
          - aicenter-hit-count-update
    - exclude:
        namespaces:
          - fleet-system
          - cattle-gatekeeper-system
          - default
    - exclude:
        labels:
          app: csi-snapshotter
    - exclude:
        labels:
          longhorn.io/job-task: backup
    - exclude:
        labels:
          app: csi-resizer
    - select: {}
EOF
kind: ClusterFlow
metadata:
spec:
  filters:
    - tag_normaliser:
  globalOutputRefs:
    - es-output
  match:
    - select:
        container_names:
          - istio-proxy
        namespaces:
          - istio-system
    - exclude:
        container_names:
          - istio-proxy
          - istio-init
    - exclude:
        namespaces:
          - fleet-system
          - default
    - exclude:
        labels:
    - exclude:
        labels:
    - exclude:
        labels:
          app: csi-resizer
    - select: {}
EOF
系统会收集集群中的日志并将其记录到 ClusterOutput 中。
配置 Kibana​
  1. 在侧边栏上选择“分析”下的“发现” 。
  2. 选择“创建索引模式” ,然后选择 “创建名为 Fluentd 的索引模式” 。
  3. 在“配置设置”窗口中选择“我不想使用时间筛选器”。
  4. 在侧边栏上选择“Kibana”下的“发现” 。
    • 您可以在仪表板中查看日志。
    • 记录对 UiPath 命名空间和特定服务的查询:
此页面有帮助吗?
连接
需要帮助? 支持(opens in new window)
保持更新
