Process Mining
Última actualización 15 de oct. de 2025
Eficiencia - Rendimiento del proveedor
Eficiencia: rendimiento del proveedor es el panel en el que puedes analizar el rendimiento de tus proveedores en el proceso Purchase-to-Pay. Muestra información detallada sobre las tasas de entrega a tiempo, los valores totales por proveedor y el número de proveedores únicos por categoría.
Supplier performance overview
Check out KPIs for a detailed description of the KPIs related to supplier performance.
Dahsboard charts
The following table describes the dashboard charts of the Efficiency - Order process velocity dashboard.
ChartDescripción
Supplier analysisDisplays supplier performance and activity metrics for the end-to-end process, helping evaluate supplier efficiency, reliability, and impact on overall process performance.
One time supplier analysisDisplays purchasing activity across material groups, showing how many suppliers are used and how many of them are one-time suppliers. This enables you to identify cases where suppliers were used only once, which can reveal inefficiencies or highlight opportunities for supplier consolidation.
TendenciasThe graph on the Trend chart shows the values of the selected metric over time, based on the Purchase order creation date.
Note: You can select different metrics and fields to change the context.
  • Supplier performance overview
  • Dahsboard charts
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
