Process Mining
Última actualización 15 de oct. de 2025
Efficiency - Order process velocity
The Order process velocity dashboard enables you to analyze and monitor the speed and efficiency of purchase order execution across the end-to-end Purchase to Pay process.
Order process velocity overview
Check out KPIs for a detailed description of the KPIs related to order process velocity.
Dahsboard charts
The following table describes the dashboard charts of the Efficiency - Order process velocity dashboard.
ChartDescripción
PR to GR milestones
A bar chart that shows the time intervals and milestones from the creation of the Purchase requisition (PR) to the completion of a Goods receipt (GR).
The PR to GR milestones chart allows you to track the flow, timing, and efficiency of the end to end process from purchase requisition to goods delivery.
Revision PO items analysisA bar chart that provides information on the number and of changes made to purchase order (PO) items within the end-to-end process.
Revision events analysis
A bar chart that provides information on the number, type, and distribution of revision (change) events that occurred across PO items in the end-to-end process.
The Revision event analysis chart allows you to analyze process instability and rework trends that reduce speed and impact the number of first time right PO items.
TendenciaThe graph on the Trend chart shows the values of the selected metric over time, based on the Purchase order creation date.
Note: You can select different metrics and fields to change the context.
  • Order process velocity overview
  • Dahsboard charts
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
