Process Mining
Última actualización 15 de oct. de 2025
Cumplimiento - Compra de Maverick
Cumplimiento: compras de Maverick es el panel donde puede analizar su proceso con respecto a la compra de Maverick. Le permite analizar los artículos de la orden de compra etiquetados con una o más etiquetas de compra independientes.
Maverick buying overview
Check out KPIs for a detailed description of the KPIs related to supplier performance.
Dahsboard charts
The following table describes the dashboard charts of the Efficiency - Order process velocity dashboard.
ChartDescripción
CondicionesDisplays supplier performance and activity metrics for the end-to-end process, helping evaluate supplier efficiency, reliability, and impact on overall process performance.
AnalyisProvides information on how much buying activity happens outside the approved Purchase to Pay process, and enables you analyze the extent of non-compliant purchasing activity by supplier, measured through the Maverick PO items rate.
TendenciasThe graph on the Trend chart shows the values of the selected metric over time, based on the Purchase order item process start date.
End to end processThe process graph displays the end to end process for purchase order items regarding maverick buying.
Note: You can select different metrics and fields to change the context.
  • Maverick buying overview
  • Dahsboard charts
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
