Process Mining
Última actualización 29 de oct. de 2025
Octubre de 2025
October 29, 2025
Novedades
Purchase-to-Pay SAP app template
  • The Purchase-to-Pay SAP app template now supports multiple processes — the purchase order item process and the accounting document process — enabling you to analyze the Purchase-to-Pay process from either perspective.
  • The following process-specific dashboard is available for the Purchase-to-Pay SAP app template:
    • Accounting process
    This dashboard provides insights into KPIs relevant to the Purchase-to-Pay process in SAP related to the accounting document process.
Check out Purchase-to-Pay SAP app template for more information.
Mejoras
Diagramas de barra
The new column context menu allows Business users to easily change the column settings. The following illustration shows an example.
Import BPMN process model
Import BPMN process model now supports the Inclusive choice gateway (OR).
Consulta Tipos de Process mining para obtener más información.
Editar paneles
You can now easily copy a chart and paste it in a different location within the same dashboard or across dashboards. Copying and pasting a chart allows you to reuse your charts and make modifications without having to create entirely new charts.
Simulación de procesos
Automation rate is now available as a node metric for the simulation process graph.
15 de octubre de 2025
Novedades
The following process-specific dashboards are available for the Purchase-to-Pay SAP app template:
  • Eficiencia: velocidad del proceso de pedido
  • Eficiencia: rendimiento del proveedor
  • Cumplimiento: compra de Maverick
These dashboards provide insights into KPIs relevant to the Purchase-to-Pay process in SAP.
Mejoras
Transformaciones de datos
Cuando se produce un error de compilación SQL durante la transformación de datos, el archivo afectado se detecta y vincula automáticamente. Puedes seleccionar el enlace para ir directamente al archivo donde puedes solucionar el problema.
La siguiente ilustración muestra un ejemplo.
Editor de panel
Los paneles marcados como ocultos ahora son visibles y accesibles en modo Vista previa , lo que te permite probar y depurar paneles y gráficos mientras los editas.
Input data mapping
You can now use the Search option to find a specific field in the field mapping step of the input data mapping.
Análisis de causa raíz
Positive influencers are now indicated with a ‘+’ sign to distinguish them from negative influencers, which are marked with a ‘–’ sign.
7 de octubre de 2025
Fe de erratas: añadida el 15 de octubre de 2025
Esta característica no estaba disponible el día del anuncio original:
Descubrir el modelo de proceso
Importar el modelo de proceso BPMN y descubrir el modelo de proceso ahora admiten la puerta de enlace de elección inclusiva (OR).
Simulación de procesos (disponibilidad general)
La simulación de procesos ya está disponible de forma general.
Con la simulación de procesos puedes comparar el comportamiento real de tus procesos con la versión modelada, revelando inconsistencias y oportunidades de mejora. La simulación de procesos te permite simular cambios en los procesos utilizando los datos existentes de Process Mining para obtener información sobre los posibles impactos en los tiempos de procesamiento y el rendimiento general.
Consulta Simulación de procesos para obtener más información.
Novedades
Editor de configuración de lógica
El operador GROUPED by para expresiones agregadas, agrupa los valores de campo o los resultados de la expresión por los valores del campo especificado. Cada valor único (o combinación de valores) forma un grupo.
La siguiente ilustración muestra un ejemplo del operador GROUPED by :
(COUNT of (IF Activity = Final check of invoice THEN Process event ID)) GROUPED by Case ID
Consulta Agregados para obtener más información.
Mejoras
  • Ahora puedes simular una tasa de automatización actualizada utilizando el escenario Añadir automatización o agente.
  • El panel Simulación ahora muestra el KPI Tasa media de automatización .
Loading data using CData Sync
La opción Cargar datos mediante CData Sync en el asistente ahora proporciona el URI para el contenedor de blob en la página de configuración de extracción . Puedes copiar el URI y utilizarlo al configurar una conexión de destino en CData Sync.
Consulta Crear una conexión de destino para obtener más información.
Obtén la ayuda que necesitas
Foro de la comunidad UiPath
Confianza y seguridad
