Automation Hub user guide
Column Information
Column reference for the Automation Pipeline table views in Automation Hub, listing all available columns including revised KPI fields and their display conditions.
Please find below a list containing all the columns available in the table views from the Automation Pipeline module.
The order of columns is alphabetical, except for the first eight default columns.
Column TitleDescriptionSource
Automation NameDisplays the name defined by the user in the Submit an idea. Under the name, is displayed the date when the last update was performed on the automation. Under "Last Modified" date, is displayed the date when the automation was submitted.Idea/Automation Profile page > About section
Last ModifiedDisplays the date when the last update was performed on the automation, in the mm/dd/yyyy format.Idea/Automation Profile page > About section
Date SubmittedDisplays the date when the automation was submitted in mm/dd/yyyy format.Idea/Automation Profile page > About section
Automation IDA unique (alpha)numeric identifier manually assigned to the idea.Idea/Automation Profile page > About section
Auto-generated IDA unique ID of the automation idea from the databaseIdea/Automation Profile page > About section
PriorityThe priority level selected for an idea.Idea/Automation Profile page page
DescriptionThe automation idea description entered during the submission process.Idea/Automation Profile page > About section
CategoriesThe automation categories selected during the submission process.Idea/Automation Profile page > About section
TagsCustom tags for ideas or automations.Idea/Automation Profile page > About section
Submitter's Business UnitThe company division/business unit assigned when adding a user.User Profile page
Submitter's DepartmentThe company department assigned when adding a user.User Profile page
RPA Software VendorThe RPA Software Vendor selected when the Cost Benefit Analysis is performed.Idea/Automation Profile page > Cost Benefit Analysis
Automation TypeThe type of automation (attended/unattended) selected when the Cost Benefit Analysis is performed.Idea/Automation Profile page > Cost Benefit Analysis
License TypeThe license type selected when the Cost Benefit Analysis is performed.Idea/Automation Profile page > Cost Benefit Analysis
Launch DateTimestamp when the automation idea was moved to Live Phase and Status changed to In Production. Date can be overridden from the Cost Benefit Analysis page - Actual & New Estimate table.N/A
Idea typeShows the path chosen to share the idea/automation in the platform, displaying all submission paths (Employee-driven, CoE-driven, Citizen Developer, Process Mining, Task Mining, Citizen Developer)Selected submission type
Development TypeThe development source selected for each idea.Idea/Automation Profile page
PhaseThe stage of the idea/automation providing information about its life cycle.Idea/Automation Profile page
StatusThe status associated with the idea/automation phase providing a granular tracking of its life cycle.Idea/Automation Profile page
Idea Phase ApproverName of the Idea Approver and date when the idea was reviewed.N/A
Launch Assessment ApproverName of the Program Manager and date when the Assessment was launched. (action no longer available)N/A
Qualification Phase ApproverName of the Program Manager and date when the idea was reviewed.N/A
Published to StoreAvailable only for accounts that have migrated to the setup in Automation CloudTM and with Automation Store enabled. It shows if the automation has reached Live - In Production and has been published to the Store.N/A
CollaboratorsThe users assigned as collaborators for the idea/automation.Idea/Automation Profile page > Collaborators
Applications UsedThe name of the application, the version, and language is displayed.Idea/Automation Profile page > About section > any Assessment that contains the application question
Idea ScoreRepresents an overall score indicating how good of a candidate the idea is for automation. It is computed based on the High-Level assessment answers.Idea/Automation Profile page > About section > Idea Score chart in Idea phase
Automation PotentialA percentage indicator computed to determine how much of the process can be successfully automated.Idea/Automation Profile page > About section > Assessment KPIs section
Revised Automation PotentialReflects revised data from Cost Benefit Analysis page in Volume Split Estimations: Automation Potential value in Final After Automation column. By default, it's populated with the value computed for the Automation Potential in the Detailed assessment. Users with editing rights can modify it.Idea/Automation Profile page > Cost Benefit Analysis
Potential BenefitKPI computed based on the Citizen Developer assessment, for automations shared via Share an Automation form.Automation Profile page: Potential Benefit (across company)
Revised Benefit per company (hours saved/year)Value calculated from Total Time to perform the work(AS IS) multiplied by the Revised Automation Potential. Where Total Time to perform the work(AS IS) value is taken from the Detailed Assessment.Idea/Automation Profile page > Cost Benefit Analysis
Revised Benefit per employee (hours saved/year)Value calculated by dividing the Revised Benefit per company (hours saved/year) by the Number of Employees. Where Number of employees value is taken from the Detailed Assessment.Idea/Automation Profile page > Cost Benefit Analysis
Revised Benefit per company (FTEs)Value calculated from FTEs Required multiplied by the Revised Automation Potential. Where FTEs Required value is taken from the Detailed Assessment.Idea/Automation Profile page > Cost Benefit Analysis
Revised Benefit per employee (FTEs)Value calculated from Revised Benefit per company(FTEs) divided by the Number of Employees. Where Number of employees value is taken from the Detailed Assessment.Idea/Automation Profile page > Cost Benefit Analysis
Number of RobotsThe number of robots estimated by the algorithm to be needed for automating the idea.Idea/Automation Profile page > Cost Benefit Analysis
FTR OverriddenRepresents the value overridden by user with editing rights in the Cost Benefit Analysis page for the estimated numbers of robots needed for automating the idea.Idea/Automation Profile page > Cost Benefit Analysis
Revised Benefit per company (currency/year)Value calculated from Total Cost(AS IS) multiplied by the Revised Automation Potential. Where Total Cost(AS IS) value is taken from the Detailed Assessment.Idea/Automation Profile page > Cost Benefit Analysis
Revised Benefit per employee (currency/year)Value calculated from Revised Benefit per company(currency/year) divided by Number of Employees. Where Number of employees value is taken from the Detailed Assessment.Idea/Automation Profile page > Cost Benefit Analysis
Rolled up benefit (hours saved/year)The combined estimated hours saved per year from the automations linked to the steps of a business process. Only links included in the benefit rollup contribute.Business process entry > Linked Automations
Rolled up benefit (currency/year)The combined estimated monetary benefit per year from the automations linked to the steps of a business process. Only links included in the benefit rollup contribute.Business process entry > Linked Automations
Rolled up benefit (FTEs)The combined estimated full-time equivalents (FTEs) freed by the automations linked to the steps of a business process. Only links included in the benefit rollup contribute.Business process entry > Linked Automations
Revised Ease of ImplementationReflects the corresponding % as per the selection done in Cost Benefit Analysis: for Easy → EOI value is 83% for Medium → EOI value is 50% for Difficult → EOI value is 18% Else, if no selection was done, the system displays the EOI % computed by the Detailed Assessment algorithm.Idea/Automation Profile page > Cost Benefit Analysis
Est. Implementation CostsThe estimation of the implementation costs required for this idea.Idea/Automation Profile page > Cost Benefit Analysis
Est. Running CostsThe estimation of the costs required for the idea to run for 1 year.Idea/Automation Profile page > Cost Benefit Analysis
Est. Net Benefit Year 1Cost per year for the process AS IS (computed in the Detailed assessment) - Cost with humans performing the manual process for the transactions that could not be automated - Implementation people cost - Running costs/year.Idea/Automation Profile page > Cost Benefit Analysis > Estimated Costs & Benefits chart
Est. Net Benefit Year 2Cost per year for the process AS IS (computed in the Detailed assessment) - Cost with humans performing the manual process for the transactions that could not be automated - Running costs/year. The Running cost/year = RPA software costs + Other Software costs + Support team + Infrastructure + Other costs.Idea/Automation Profile page > Cost Benefit Analysis > Estimated Costs & Benefits chart
PDD LinkField populated only if a PDD link is embedded for the idea. The documents that have been uploaded are not displayed.Idea/Automation Profile page > Documentation
InterestsThe number of interests received by the automation.Idea/Automation Profile page
DownloadsDisplay the number of times the automation has been downloaded from the Automation Store.Automation Store
RequestsDisplay the number of times the automation has been requested. Available only for accounts that have not migrated to the setup in Automation CloudTM.Idea/Automation Profile page
Detailed Assessment VersionDisplays the version name of the detailed assessment for each ideaIdea/Automation Profile page > About section > Assessment
Number of ApplicationsDisplays how many applications have been selected in any assessment for each ideaIdea/Automation Profile page > About section > any Assessment that contains the application question
Number of Automation Store ReviewsDisplays the number of reviews added in the Automation Store profileAutomation Store
Number of CollaboratorsDisplays the number of collaborators added to the idea.Idea/Automation Profile page > Collaborators
Number of CommentsDisplays the number of comments and replies added to the idea.Idea/Automation Profile page > About section
Number of ComponentsDisplay the number of components added to the idea.Idea/Automation Profile page > Components
Number of DocumentsDisplays the number of uploaded documents to the idea.Idea/Automation Profile page > Documentation
Number of FollowersDisplays the number of users who have clicked on the follow option for the idea.Idea/Automation Profile page
Number of Media ItemsDisplays the number of media items selected.Idea/Automation Profile page > About section > Misc assessment
Number of Similar AutomationsDisplays the number of similar automations selected.Idea/Automation Profile page > About section > Misc assessment
Idea flow variableDisplays the workflow level variable.
Please select a reason for rejecting the ideaDisplays the reason why the idea was rejected.Idea/Automation Profile page > Phase and status
Leave a comment for rejecting the ideaDisplays the comment on why the idea was rejectedIdea/Automation Profile page > Phase and status
Please select a reason for rejecting the automationDisplays the reason why the automation was rejected.Idea/Automation Profile page > Phase and status
Leave a comment for rejecting the automationDisplays the comment on why the automation was rejected.Idea/Automation Profile page > Phase and status
Leave a comment for archiving the ideaDisplays the comment on why the idea was archived.Idea/Automation Profile page > Phase and status
Leave a comment for archiving the automationDisplays the comment on why the automation was archived.Idea/Automation Profile page > Phase and status
Leave a comment for deleting the automationDisplays the comment on why the automation was deleted.Idea/Automation Profile page > Actions
Note:
The values for Revised KPIs are populated in the Automation Pipeline only after editing and saving the Cost Benefit Analysis section within the Automation Profile page.
Note:
More columns that are part of the Detailed, High level , Citizen Developer and Change Request assessments can appear in the Automation Pipeline. As long as a minimum of one idea is linked to a version of an assessment, then the questions part of that assessment are displayed as pipeline columns, showing the answers collected with that idea.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
