Automation Hub user guide
- Getting Started
- Permissions
- Starting as
- Admin Console
- Workspace
- Explore
- Submit a new entry
- Dashboards
- My Tasks
- Notifications
- Email Notifications
- Resources
- Process Mining Integration
- Studio Integration
- Task Capture Integration
- Automation Hub - Automation Cloud Integration
- Automation Hub - Maestro integration
- Automation Hub - Task Mining Integration
- Automation Store
- Additional Resources
Pre and Post Automation
Pre and Post Automation section in Automation Hub for comparing process characteristics before and after implementation, including duration, error rate, and volume metrics.
The Pre and Post Automation allows you to illustrate the automation's characteristics by listing the before and after being implemented process information.
Average Process Duration: enter the before and after values describing how long it takes to perform this process once.
Average Error Rate: enter the before and after percentages of error occurrence.
Average Rework Time: enter the before and after values in minutes of how long it takes to resolve an error.
