Automation Hub user guide
Submit an Automation Flow
Automation submission flow in Automation Hub, from profile creation through the review stages that apply based on the submitter's permission level.
As soon as you submit an automation, the below flow is initiated:
  1. An Automation Profile is created for your automation. Check it to follow its evolution and updates.
  2. The automation undergoes several reviews. This depends on your assigned permission level. Check out the for more information.
Below you can find a graphic display of the Citizen Development automation flow:
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
