Setup credentials for the SQL Server database
Se requieren las credenciales de la base de datos de SQL Server para configurar una conexión de destino para cargar los datos extraídos en Process Mining en Automation Suite.
Uploading data to Process Mining (Automation Suite) requires access to the SQL Server database location to which the extracted data needs to be uploaded. To set up a SQL Server destination connection you need the following setup parameters to authenticate access to the SQL Server database location.
  • Server
  • Database
  • Schema
  • Role
