uipathctl reference guide
Last updated Feb 24, 2025
uipathctl config tls-certificates get
Get TLS certificates observed in the cluster in pem format.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config tls-certificates get [flags]uipathctl config tls-certificates get [flags]
Examples
        # Get the current tls certificates from the cluster
        # Get the current tls certificates from the cluster with additional certificate information
        uipathctl config tls-certificates get --show-details
        # Get the current tls certificates from the cluster identified by the current context in the kubeconfig file
        uipathctl config tls-certificates get --kubeconfig cluster.kubeconfig
Options
  -h, --help           help for get-tls-certificates
--show-details   if true, additional tls certificate information will be printed  -h, --help           help for get-tls-certificates
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
