uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Reference for the uipathctl cluster migration command group and its subcommands for managing cluster state migration in Automation Suite.
Manage the cluster state migration, such as object store, secrets, or Insights data migration.
uipathctl cluster migration [flags]
Examples
# Run migration between two clusters
uipathctl cluster migration run input-target.json --target-kubeconfig kubeconfig.target --kubeconfig kubeconfig.source
# Runs migration of cluster state in offline cluster
uipathctl cluster migration export --kubeconfig kubeconfig.source
# Run cluster import
uipathctl cluster migration import --kubeconfig kubeconfig.target
Options
-h, --help help for migration
