uipathctl reference guide
uipathctl cluster maintenance
Reference for the uipathctl cluster maintenance command group and available subcommands in Automation Suite.
Description​
Perform maintenance operations on the cluster.
uipathctl cluster maintenance [flags]
Examples​
# Enable maintenance mode for the cluster
uipathctl cluster maintenance enable
     Disable maintenance mode for the cluster
uipathctl cluster maintenance disable
     Check if the cluster is in maintenance mode
uipathctl cluster maintenance is-enabled
Options​
  -h, --help   help for maintenance
Options inherited from parent commands​
  • Description​
  • Examples​
  • Options​
  • Options inherited from parent commands​
Connect
Stay updated
