- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Rotate exchanges the current SAML data with the future one.
The command defaults to the current context in the
kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config saml-certificates rotate [flags]uipathctl config saml-certificates rotate [flags]# Rotate the saml certificates from the cluster
uipathctl identity rotate-saml-certificates
# Rotate the saml certificates from the cluster identified by the current context in the kubeconfig file
uipathctl identity rotate-saml-certificates --kubeconfig cluster.kubeconfig # Rotate the saml certificates from the cluster
uipathctl identity rotate-saml-certificates --kubeconfig cluster.kubeconfig--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s) --context string name of the kubeconfig context to use
