uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Reference for the uipathctl snapshot backup create command, which backs up a named snapshot of the cluster in Automation Suite.
Back up the snapshot of the cluster. NAME denotes the name associated with the snapshot backup.
uipathctl snapshot backup create NAME [flags]
Options
-h, --help help for create
-w, --wait wait until the backup completes (default false)
