uipathctl reference guide
uipathctl snapshot restore history
Reference for the uipathctl snapshot restore history command, which displays the restore history for cluster snapshots in Automation Suite.
Description​
Show the restore history.
uipathctl snapshot restore history [flags]
Options​
  -h, --help   help for history
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Stay updated
