uipathctl reference guide
Last updated Feb 24, 2026
uipathctl config token-signing-certificates
Manage Token Signing certificates.
uipathctl config token-signing-certificates [flags]
Options
  -h, --help   help for token-signing-certificates
      --timeout duration    timeout of the command (default 1h0m0s)[
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
