uipathctl reference guide
Last updated Feb 24, 2025
uipathctl snapshot restore create
Restore a specific snapshot of the cluster. NAME is the name of the restore and, --from-snapshot accepts the name of the snapshot to restore.
uipathctl snapshot restore create NAME [--from-snapshot SNAPSHOT_NAME] [options] [flags]uipathctl snapshot restore create NAME [--from-snapshot SNAPSHOT_NAME] [options] [flags]
Options
-s, --from-snapshot string   Name of the snapshot to restore
  -h, --help                   help for create
  -w, --wait                   wait until the restore completes (default false)  -s, --from-snapshot string   Name of the snapshot to restore
      --timeout duration    timeout of the command (default 1h0m0s)      --context string      name of the kubeconfig context to use
