- Overview
 - Pre-installation
 - Cluster administration
- uipathctl cluster
 - uipathctl cluster migration
 - uipathctl config argocd
 - uipathctl version
 - Backup and restore
- uipathctl snapshot
 - uipathctl snapshot backup
 - uipathctl snapshot delete
 - uipathctl snapshot list
 - uipathctl snapshot restore
 - Certificate management
 - Upgrade
 - Authentication
 - Monitoring and alerting
 - Troubleshooting
uipathctl reference guide
Last updated Feb 24, 2025
Load the configuration file found in the parameter, and lists the applications created based on it. The runtime configuration is used to determine which applications are required. The output is always in tabular format. By default, the list is sorted alphabetically.
uipathctl manifest list-applications PATH [flags]uipathctl manifest list-applications PATH [flags]# List the applications which are installed based on the configuration found in input.json
        uipathctl manifest list-applications input.json
        # List the applications which are installed based on the configuration found in input.json.
        # Sort them by the order in which they need to be installed based on dependencies between them.
        uipathctl manifest list-applications input.json/cluster_config.json --sort-by topological
        # List the applications without headers
        uipathctl manifest list-applications input.json/cluster_config.json --no-headers
        # Override the initial list of enabled components
        uipathctl manifest list-applications input.json/cluster_config.json --override gatekeeper,redis
-h, --help                 help for list-applications
--is-required string   to check whether the component needs to install
--no-headers           if true, print the output without headers
--override strings     optional list of components to override the components enabled in input.json/cluster_config.json file
--sort-by sortBy       if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical)  -h, --help                 help for list-applications
--sort-by sortBy       if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical)--context string      name of the kubeconfig context to use
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
