- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl reference guide
Last updated Feb 28, 2026
Rotate exchanges the current Token Signing certificate data with the future one.
The command defaults to the current context in the kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config token-signing-certificates rotate [flags]
Examples
# Rotate the token signing certificates from the cluster
# Rotate the token signing certificates from the cluster identified by the current context in the kubeconfig file
uipathctl config token-signing-certificates rotate --kubeconfig cluster.kubeconfig
Options
-h, --help help for rotate
--namespace string The namespace where UiPath Automation Suite is deployed (default "uipath")
--timeout duration timeout of the command (default 5h0m0s)
