- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl config alerts add-email
uipathctl reference guide
Last updated Feb 24, 2025
Add email receiver for Alertmanager.
uipathctl config alerts add-email [flags]
# Adds new email receiver based on parameters passed in command
uipathctl config alerts add-email --name test --to "admin@example.com" --from "admin@example.com" --smtp "server.mycompany.com:443" --username admin --password "somepassword" --require-tls --ca-file "file path too rootCA" --cert-file "file path too server certificate" --key-file "file path too server key file"
--ASEA Boolean flag to denote whether the cluster is ASEA or not
--ca-file string File path containing the CA certificate of the SMTP server. This parameter is optional if the CA is private
--cert-file string File path containing the certificate of the SMTP server. This parameter is optional if the certificate is private
--from string The sender's email address
-h, --help help for add-email
--key-file string File path containing the private key of the certificate for the SMTP server. This parameter is required if the certificate is private
--name string Name of the email configuration
--password string SMTP authentication Password
--require-tls Boolean flag to denote that TLS is enabled at the SMTP server (default true)
--send-resolved Boolean flag to denote whether to send email on resolved alert (default true)
--smtp string SMTP server URL or IP, including port
--to string Receiver's email address
--username string SMTP authentication Username
