uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
Reference for the uipathctl cluster maintenance is-enabled command and its flags in Automation Suite.
Check if maintenance mode is enabled for the cluster.
uipathctl cluster maintenance is-enabled [flags]
Options
-h, --help help for is-enabled
