uipathctl reference guide
uipathctl prereq
Reference for the uipathctl prereq command, flags, and options for running prerequisite checks in Automation Suite.
Description​
Runs the prerequisite checks.
uipathctl prereq [flags]
Options​
      --excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for prereq
      --included strings   components to be included in the execution, defaults to all
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
