uipathctl reference guide
Last updated Feb 28, 2026
uipathctl config argocd generate-rbac
The following command generates a sample RBAC configuration file for ArgoCD. See RBAC Configuration - Argo CD - Declarative GitOps CD for Kubernetes.
uipathctl config argocd generate-rbac [flags]
Examples
# Generate a sample rbac configuration file for ArgoCD:
  uipathctl config generate-rbac generate-rbac
Options
  -h, --help   help for generate-rbac
  • Description
  • Examples
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
