uipathctl reference guide
Last updated Feb 24, 2025
uipathctl resource report
Generates a report on the resources in the cluster.
uipathctl resource report [flags]uipathctl resource report [flags]
Examples
# Generates a resource report
Options
-h, --help            help for report
--output output   The output of the report. Can be one of: json, minreqsgo (default json)  -h, --help            help for report
--timeout duration    timeout of the command (default 1h0m0s)--context string      name of the kubeconfig context to use
