uipathctl reference guide
uipathctl config orchestrator
Reference for the uipathctl config orchestrator command group and its flags for managing Orchestrator custom configuration in Automation Suite.
Description​
Change the Orchestrator custom configuration.
uipathctl config orchestrator [flags]
Options​
  -h, --help   help for orchestrator
Options inherited from parent commands​
  • Description​
  • Options​
  • Options inherited from parent commands​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
