uipathctl reference guide
uipathctl cluster maintenance enable
Enable maintenance mode for the cluster.
uipathctl cluster maintenance enable [flags]
Options
  -h, --help   help for enable
  • Description
  • Options
  • Options inherited from parent commands
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
