uipathctl reference guide
- Overview
- Pre-installation
- Cluster administration
- uipathctl cluster
- uipathctl cluster migration
- uipathctl config argocd
- uipathctl version
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
uipathctl manifest
Reference for the uipathctl manifest command, flags, and options for managing file-based manifests and desired configurations in Automation Suite.
Manage the file-based manifest or desired configuration.
uipathctl manifest [flags]
Options
-h, --help help for manifest
