- Overview
- Pre-installation
- Cluster administration
- Backup and restore
- uipathctl snapshot
- uipathctl snapshot backup
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Certificate management
- Upgrade
- Authentication
- Monitoring and alerting
- Troubleshooting
OUT OF SUPPORT
uipathctl reference guide
Last updated Apr 29, 2025
Get TLS certificates observed in the cluster in
pem format.
The command defaults to the current context in the
kubeconfig file. If the --kubeconfig flag is set, it uses the kubeconfig file specified by the flag.
uipathctl config tls-certificates get [flags]uipathctl config tls-certificates get [flags]# Get the current tls certificates from the cluster
# Get the current tls certificates from the cluster with additional certificate information
uipathctl config tls-certificates get --show-details
# Get the current tls certificates from the cluster identified by the current context in the kubeconfig file
uipathctl config tls-certificates get --kubeconfig cluster.kubeconfig
-h, --help help for get-tls-certificates
--show-details if true, additional tls certificate information will be printed -h, --help help for get-tls-certificates
--show-details if true, additional tls certificate information will be printed--context string name of the kubeconfig context to use
--timeout duration timeout of the command (default 1h0m0s)--context string name of the kubeconfig context to use
